4 bit counter digital project
Discussion in 'The Projects Forum' started by mahmoudathab, May 20, 2011.
  1. mahmoudathab
    May 20, 2011
    24
    i have a problem with a 4 bit counter that counts from 0 to 9. i found the circuit in "digital fundamentals" by floyed and iam sure i connected everything right but the 7 sigment keep showing random numbers like 9,7,4,1,0 and other wierd figures so can someone please help me with this.
    here is the diagram from the book:
    http://imageshack.us/photo/my-images/827/unledyns.png/
    oh and i used 555 timer as astable multivibrator and set it to 1 hz.
  2. Xufyan
    Member
    Aug 3, 2010
    114
    have you connected 7 Segment to 7447 IC properly ??
    see the attachments
  3. Georacer
    Nov 25, 2009
    5,151
    1,266
    Good point. 7-seg pin layout is tricky.
    You can troubleshoot your counter individually by sampling the output of the counter before you feed it into the 7447 IC. If you get a correct binary count (0000, 0001, 0010...) you problem probably lies within the 7447 circuitry.
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    Xufyan likes this.
  5. mahmoudathab
    May 20, 2011
    24
    thx alot guys the problem was with the 7-sigment connection:D
