i want to make a structual description of a 4bit comparator using GENERATE stratements.
my code is this:
When i try to compile i have this mistakes:
Anyone could Help? Thanks!
my code is this:
Rich (BB code):
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.std_logic_arith.all;
ENTITY temp1 IS
port(Ain,Bin : in std_logic_vector(4 downto 0);
PrevA,PrevB: in std_logic;
AgB, AlB: out std_logic);
END ENTITY temp1;
ARCHITECTURE structural OF temp1 IS
signal s1,s2,s3,s4,s5,s6: std_logic;
component bit_slice_comp is
port(A,B : in std_logic;
PrA,PrB: in std_logic;
AgBout, AlBout: out std_logic);
end component bit_slice_comp;
Begin
comp_iterate: for i in 0 to 3 generate
comp: bit_slice_comp port map (A=> Ain(i), B=> Bin(i), PrA => PrevA, PrB => PrevB, AgBout => AgB, AlBout =>AlB);
-- comp: bit_slice_comp port map ( Ain(i)=>A, Bin(i)=>B, PrevA => PrA, PrevB => PrB, AgB => AgBout , AlB => AlBout );
calculation: process
begin
s1<= Ain(i) and PrevA;
s2<= Ain(i) and (not Bin(i));
s3<= (not Bin(i)) and PrevA(i);
s4<= PrevB(i) and Bin(i);
s5<= Ain(i) and PrevB(i);
s6<= (not Ain(i)) and Bin(i);
AgB <= s1 or s2 or s3;
AlB <= s4 or s5 or s6;
end process calculation;
end generate;
END ARCHITECTURE structural;
Rich (BB code):
* Error: temp1_structural.vhd(38): Prefix of indexed name must be an array.
** Error: /temp1_structural.vhd(38): Type error resolving infix expression "and" as type ieee.std_logic_1164.std_logic.
** Error:temp1_structural.vhd(40): Prefix of indexed name must be an array.
** Error:temp1_structural.vhd(40): Type error resolving infix expression "and" as type ieee.std_logic_1164.std_logic.
** Error: temp1_structural.vhd(41): Prefix of indexed name must be an array.
** Error: temp1_structural.vhd(41): Type error resolving infix expression "and" as type ieee.std_logic_1164.std_logic.
** Warning: [2] temp1_structural.vhd(46): (vcom-1090) Possible infinite loop: Process contains no WAIT statement.
** Error: temp1_structural.vhd(48): VHDL Compiler exiting
