4 bit binary counter built from sr latches
Discussion in 'The Projects Forum' started by KRS, Apr 22, 2010.
  1. KRS
    Apr 21, 2010
    Im trying to simulate/build a 4bit binary counter in crocodile technology but the only latches/flip flops that i have available are sr latches with a single set and reset input and a single 'Q' output. There are loads of binary counter circuits on the web but they all use either j-k, d-type or t-type latches :(
    can anyone tell me how i will need to connect up the sr latches to make a binary counter using them?
  2. kingdano
    Apr 14, 2010
    The great thing about JK flip flops is that you can configure them to run as SR latches.
    You should look into this, and see if you can find the similarities and then modify a j-k counter circuit.
