4-bit ALU
Discussion in 'General Electronics Chat' started by assassinelec, Jan 9, 2012.
  1. assassinelec
    Mar 22, 2011
    13
    hi all, i want to make a 4-bit ALU with logic gates only and i'm looking for a complete circuit diagram that can allow me to do so, till now i can't find anyone all the circuits i found are missing the reset and CLK buttons, does any one have the complete circuit for a 4-bit ALU ? , any help would be appreciated.
  2. kubeek
    Sep 20, 2005
    4,691
    806
    Alu is a combinatorial circuit, so the reset and clock inputs would serve no purpose.
    Look here at a complete 4bit ALU, no clock or reset in there.
  3. wire
    Dec 18, 2011
    13
    I have to implement 8 bit Alu.....but it should be a sequential circuits,,,,,confused ....Basically I would use registers to store the input data and output.
  4. MrChips
    Oct 2, 2009
    12,652
    3,461
    For our final year project in digital electronics, my partner and I built a 4-bit computer using the 74181 ALU. The DG Nova minicomputer also used this chip in its CPU.
  5. kubeek
    Sep 20, 2005
    4,691
    806
    Yes. You will also need to connect flag bits in the right way to make it truly 8bit.
