4 bit adder -> parrarel adder of 4 bit numbers
Discussion in 'Homework Help' started by snk0, May 21, 2014.
  1. snk0
    May 21, 2014
    Hi, electronic circuits are more or less black magic to me. I somehow managed to do the previous tasks I had to do but unfortunately the one I have now is somewhat beyond me:(
    I have to create parrarel adder capable of adding two 4 bit numbers using 4 bit adder. The outcome should be read out from the registry in parrarel method (Im not sure if i translated this correctly)
    Equipment-
    4 invert gates
    2 NAND (2 entrances)
    8 EX-OR (2 entrances)
    74164 x2
    74165 x 2
    7483 (one bit adder) x1
    74175 x1
    74198 x 1
    7475 x1
    7495 x1
    I will be insanely greatful for help
  2. absf
    Dec 29, 2010
    1,493
    374
    What have you done so far?
    If you look at the datasheet of 7483, it is a 4-bit full adder by itself. ;)
    Allen
  3. Austin Clark
    Dec 28, 2011
    409
    44
    I think he may be confusing parallel with serial. Based on how he described the output as being "read out".
