4-16 bit decoder
Discussion in 'Homework Help' started by The_Cook, Jan 20, 2016.
  1. The_Cook
    May 29, 2014
    48
    Trying to create a 4-16 bit decoder with 4-bit input, 16 output signals. I think this is correct, can anyone verify:
  2. WBahn
    Mar 31, 2012
    18,080
    4,917
    Do you want the outputs to be active-HI or active-LO?
    What steps have you taken to verify the correctness of your design?
  3. The_Cook
    May 29, 2014
    48
    Doesn't matter if it is active-hi or active low for this one. What would you suggest I do to verify?
  4. WBahn
    Mar 31, 2012
    18,080
    4,917
    So it doesn't matter if the outputs are correct or not?
    Derive the functionality (equations or truth table or whatever) from the diagram and compare that to the function the circuit is supposed to implement.
