4-1 multiplexer
Discussion in 'Homework Help' started by furthermore, Dec 8, 2010.
  1. furthermore
    Dec 8, 2010
    The problem is to do a full adder module with data input X, Y, carry input Cin and Sum output S and carry output Cout. It says to design using 3-8 decoder, which i already did, but now I need to design it using 4-1 multiplexers, do i need to find stuff like Minterm and S1,2,3,4 ??. How can I go about solving this??
  2. Kermit2
    Feb 5, 2010
    3,845
    963
  3. Georacer
    Nov 25, 2009
    5,151
    1,266
    I would say that you spat the answer out if this pdf didn't look so professional and intimidating...
  4. furthermore
    Dec 8, 2010
    Thanks, but I didnt understand the pdf that much :/, Im taking a entry level ee design course
  5. Georacer
    Nov 25, 2009
    5,151
    1,266
    Can you write the truth table of the Full Adder, for starters?
    We can talk more after you do that.
    The theory behind that paper is that after you find the boolean expression of a function F(A,B,Cin), you use inputs A and B to drive the MUX's select pins and use the following functions to drive the input pins:
    For Input 00 -> F(0,0,Cin)
    For Input 01 -> F(0,1,Cin)
    For Input 10 -> F(1,0,Cin)
    and so on...
    P.S. You actually have to evaluate F(0,0,Cin) for those values.
