4-1 Multiplexer
Discussion in 'Homework Help' started by The_Cook, Jan 20, 2016.
  1. The_Cook
    May 29, 2014
    48
    Hi, I need to create a 4-1 multiplexer with a 2 bit selector and 16 bit input/output values. Would this be the right circuit for this:
  2. WBahn
    Mar 31, 2012
    18,069
    4,905
    That has 1 bit input/output values. How are you planning to use this circuit in order to get 16 such values?
  3. The_Cook
    May 29, 2014
    48
    Would you just create 4 of those and connect them together? That would give 16 bit inputs right?
  4. WBahn
    Mar 31, 2012
    18,069
    4,905
    How would you use four of them?
    How many outputs would that give you?
    You need to take a step back and be sure you know what it is you are trying to implement before you try to implement it.
    First step in the problem solving process: make sure you understand the problem you are trying to solve. It's also often the hardest part of the problem solving process.
