4-1 circuit...i'm new to this.
Discussion in 'Homework Help' started by VAALLDAY434, Apr 28, 2010.
  1. VAALLDAY434
    Apr 28, 2010
    11
  2. BMorse
    Sep 26, 2009
    2,675
    234
    What is it that you do not understand?? It seems very straight forward...
    B. Morse
  3. VAALLDAY434
    Apr 28, 2010
    11
    I dont know anything about these and wanted to know if someone could do a 4-1 of this and send me the end results
  4. VAALLDAY434
    Apr 28, 2010
    11
    anyone......
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    What do you mean, a 4-1 circuit?
  6. VAALLDAY434
    Apr 28, 2010
    11
    design a 4 to 1 multiplexer
  7. BMorse
    Sep 26, 2009
    2,675
    234
  8. VAALLDAY434
    Apr 28, 2010
    11
    Im lost......
  9. VAALLDAY434
    Apr 28, 2010
    11
    read the article from above, however, I dont understand the connections in Semicir
  10. retched
    Dec 5, 2009
    5,201
    313
    Ok, Im confused.. Are you trying to figure out how to use Simcir, or a specific circuit?
  11. VAALLDAY434
    Apr 28, 2010
    11
    how to use semicir to create a 4-1 mulitplexer
  12. VAALLDAY434
    Apr 28, 2010
    11
    how to use semicir to create a 4-1 mulitplexer...anyone
  13. bertus
    Administrator
    Apr 5, 2008
    15,809
    2,390
    Take a look at the datasheet of an DM74153.
    Bertus
  14. VAALLDAY434
    Apr 28, 2010
    11
    ^^^ Bertus Could you show me how do do this from my my post in this thread in semicir?
  15. bertus
    Administrator
    Apr 5, 2008
    15,809
    2,390
    You will have a problem building it in this program.
    The space is to limited and there are no multiple input gates.
    Copied from the datasheet.
    Bertus
  16. VAALLDAY434
    Apr 28, 2010
    11
    Thanks bertus....i Have two more questions if you could help.
    1) given hexadecimal
    0001 A2
    0002 11
    0003 FE
    What does the contents of A register after the execution of the following instructions.
    00001000 00000000 00000001
    00011000 00000000 00010001
  17. VAALLDAY434
    Apr 28, 2010
    11
    2)what is the diagram of the following?
    A B A* AB A* (+) (AB)
    0 0 1 0 1
    0 1 1 0 1
    1 0 0 0 0
    1 1 0 1 1
  18. bertus
    Administrator
    Apr 5, 2008
    15,809
    2,390
    The answer can only be given when you know what the instructions should do and whre register A is.
    The representation you now give does not say enough.
    Bertus
  19. bertus
    Administrator
    Apr 5, 2008
    15,809
    2,390
    I moved it to the homework help section as the question look like homework.
    I think you need to dive into some digital electronics pages.
    Here are some pages of the EDUCYPEDIA on digital electronics with lots of links:
    http://www.educypedia.be/electronics/digitaltechnology.htm
    Digital electronics:
    Arithmetic circuits D/A-A/D converters Number systems Codes and decoders Flip flops Technology Counters and registers General overview Technology-CMOS Digital logic Memories Technology-TTL Timers and oscillators
    Bertus
