Using a Step Up (Boost Converter), that takes an input voltage of supposedly 0.9v - 5.5Vdc.
Then it output 5Vdc @ 1.0A.
I've used the Step up Module SEVERAL times in the past with a 3.7v MNKE IMR 26650 Battery.
Works PERFECTLY. In fact, after running a few tests it performs BETTER than charging threw
USB Port on XBOX 360 Controller Charging Dock USB Output ports. Also works better than USB 3.0 port on Lenovo IdeaPad Y570 Laptop Ports. Outputs a Perfect 5.0218Vdc @ 0.400 -/+ Amps.z
So now my 3x Solar panels got here today, and I was eager to test them out, and see if I could use them with the boost converter. Tested the output voltage of each solar panel, and they were outputting 3.8vdc using 23watt CFL Lamps (5,300 kalvin Temp Color "daylight")..
They are rated for 4.5Vdc @ 1.5 watt @ 0.334 Amps output. I have the spec sheets that came inside each package, and that's what the exact specs are. (2770051) Is they're names.
WHY ARE THEY OUTPUTTING ONLY 2.081 Volts DC, at only freaking 0.003 Amps (3,184 uA) ?
I don't understand what I'm doing wrong.. Hooked up this way, the two that are in Series on the right output about 7.2 volts DC, and then on the left, I have one of em hooked up to the other two panels in parallel.
They are only measuring the current & voltage going into the Boost Converter.. Only reads 2.0 volts, and only 0.003 Amps. I really don't understand what I'm doing wrong.
Can someone please help or try to shine a little light on what I might be doing wrong? Please..? I'd really appreciate it. I've measured the current the correct way. I hooked the Red Test lead to the Red (Possitive) of the Solar Panel Positive output, and I hooked the Black Test Lead to the Red INPUT of the source where the positive connection is going to. So basically testing the current inline with the positive in & out.
I've also tested the boost convert the same way when I tested how much current was being drawn when I tested the USB Connection on the Laptop & XBOX360 Charging Dock.
Now I want to use these solar panels, to charge my Samsung Galaxy S3 phone without batteries..
Here's what I got..
Tested each panel, and still the same.. 2.082 Volts, WTF is going on..? Why do they drop so low..? I also tested the current the combined solar panels output current, and it doesn't matter if I test them combined before the diode or anything, still 0.003A @ 2.082 Volts..
Here's my setup..
Here's what I got..
Here's my setup..
