3rd year project
Discussion in 'The Projects Forum' started by Penelope, Mar 30, 2011.
  1. Penelope
    Sep 14, 2010
    5
    Hey
    Im doing a digital code lock as my third year project, the specs are as follows must use a 4x4 keypad, password/code must use letters and numbers, when u enter the correct code a solenoid opens the door, if u enter the wrong code 3 times No access appears on the LCD and buzzer is sounded. Also all numbers are displayed as * on the LCD, and finally i must be able to change the code at anytime and make it whatever length i want.
    My coide is complete up to the point where i have to be able to change the code at anytime. If anyone could help me with this final part it would be very much appreciated.
  2. DumboFixer
    Feb 10, 2009
    219
    34
    The hex file is no use. Can you please post your source code (inside code tags) so we can see what you've done ?
  3. Penelope
    Sep 14, 2010
    5
    Sorry think thats it now
