3ph speed variable drive
Discussion in 'General Electronics Chat' started by nareshkumar, Apr 16, 2009.
  1. nareshkumar
    Apr 16, 2009
    sir i have one ac 3ph speed variable drive make crompton greaves modle avs1000
    this drive have 3 pcb no [1]141-018-1speed control drive cord [2]cord no 141-107 current control cord [3]141-108-7LEDcorddis connect the control wires from the all cords please sent the detailed wiring connection
    thankyou
  2. thatoneguy
    Feb 19, 2009
    6,357
    718
    I'm afraid I do not understand the question.
    Do you need a hookup diagram for the speed controller? That would be available from the manufacturer of the speed controller.
  3. Frank W. Kidd
    Apr 14, 2009
    I can not understand your question.. but for any clue i would suggest that if you seems any serious issue in your A/C which you also can not getting than you should try for another product.. and i have one online source which can help you in getting different types of items.. they are also serving online discount coupons for any type if your home accessories..
    [SIZE=-1] " Prayer is an invisible tool which is wielded in a visible world."[/SIZE]
