3G GSM modem signal problems
Discussion in 'Wireless & RF Design' started by bobdx_cool, Apr 4, 2014.
  1. bobdx_cool
    Apr 4, 2014
    Hi
    I was just working on a project related to 3g connectivity.
    I have a 3g dongle inside a steel box. The 3g dongle does'nt seem to get the signals inside the box .
    Dont we get 3G signals inside a stainless steel box?
    Any solution for this, without replacing the steel box ?
  2. shteii01
    Feb 19, 2010
    3,500
    511
    Take it out of the box.
    Also look up Faraday Cage.
    bobdx_cool likes this.
  3. bobdx_cool
    Apr 4, 2014
    Thank you.
    Is it possible to get a signal if we use an external antenna. i.e Some modems have provision for an external aerial or some sort of aerial on the outside to the inside might help conduct the signal ??
    Or making some holes might help ???
  4. shteii01
    Feb 19, 2010
    3,500
    511
    Yes, either antenna that is outside the metal box or a hole in the metal box. Or you can connect the unit to the metal box, then the box becomes the antenna.
