3dB lower and Higher frequency.
Discussion in 'General Electronics Chat' started by nqureshi, Oct 9, 2008.
  1. nqureshi
    Oct 9, 2008
    I have a frequency Band Pass responce at 44MHz and 6MHz bandwidth. how can I calculate its 3dB lower and 3dB higher frequency. means what will be the frequency ant 3dB lower point and 3dB higher point at 44MHz and 6MHz bandwith.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If 44MHz is the center frequency, then the 3dB points are +/- 3MHz on either side - 41MHz and 47MHz. It's a bandpass filter, so both 3 dB points are negative.
  3. Ron H
    Apr 14, 2005
    7,050
    657
