3D plot suggestions?
Discussion in 'Programmer's Corner' started by panic mode, May 3, 2013.
  1. panic mode
    Thread Starter Senior Member
    Oct 10, 2011
    1,328
    305
    Hi everyone,
    I am making some software for a friend that among other things could use 3D visualization (surface plot). Any suggestions? This is not for a profit or work and it is not a must-have but it would be nice to have. I would prefer something open source or free if possible.
    By 3D I don't mean 2D graphs that are skewed to look 3D ( that i can do with System.Windows.Forms.DataVisualization.Charting). I am looking for a (preferably free or low cost) control such as ActiveX 3D surface plot.
    alternatively I could make a dirty "3D" using GDI etc.
    suggestions?
  2. joeyd999
    Jun 6, 2011
    2,756
    2,923
    Typing "3d Plot" in the Ubuntu Software Center gives me these results:
    QtiPlot
    Euler
    r-cran-misc3d
    PLplot
    qwtplot3d
    Years ago, I used to use MS Excel for 3D plotting.
  3. WBahn
    Mar 31, 2012
    18,085
    4,917
    Didn't you just make one?
    If you are looking for a control such as ActiveX 3D, why not use ActiveX 3D?
    I'm not trying to be too facetiious (okay, a little bit facetious, yes). If ActiveX 3D is not suitable, then for someone to make a reasonable suggestion it would be very helpful to know why it is not suitable.
  4. panic mode
    Oct 10, 2011
    1,328
    305
    that you joey, that was great.
    @ WBahn, no i do programming here and there but i am not a software developer. i am looking for a ready made component if possible (drop it on a form and feed data into it as with 2D chart) - not learning new tools or programming environment, developing something from scratch for one-off kind a deal but, i'll bite the bullet if there are no easy pickings...
  5. WBahn
    Mar 31, 2012
    18,085
    4,917
    Ah. I think that helps clarify what you are looking for quite a bit. What you are doing is something well outside what I do (though I will be heading that way shortly) so I don't have any suggestions. Hopefully someone will.
  6. THE_RB
    Feb 11, 2008
    5,435
    1,305
    I can't help with the "ready made component" but it's pretty trivial to do if you have any experience making graphics with lines and pixels.
    Just plot X as horizontal (+X on screen), plot Y as diagonal (+X +Y on screen) and plot Z as vertical (+Y on screen).
    It's not much harder than plotting a 2D chart.
  7. tshuck
    Oct 18, 2012
    3,531
    675
  8. panic mode
    Oct 10, 2011
    1,328
    305
    it's done and everyone is happy.
    first example is done some 2 years ago in VB6, it is a scan of a dice plotted using basic GDI (plotting individual pixels) and something I wanted to avoid. the "3D" view was obtained by skewing the data from different profiles. flat surfaces extending to the left are from robot gripper that held the dice.
    the current one is done using surface plot (here showing profile of a pen). the scan is inaccurate because i just moved sample by hand and I need to adjust the z-scale. this was based on
    http://www.codeproject.com/Articles/42174/High-performance-WPF-3D-Chart
    back to BBQ and friends... ;-)
    thanks everyone!
      File size:
      12.9 KB
      26
      File size:
      111.9 KB
      34
