3A Fuse Not Breaking
Discussion in 'General Electronics Chat' started by drguildo, Jan 15, 2014.
  1. drguildo
    Jan 15, 2014
    14
    I'm a complete beginner so please excuse the ignorance of my post.
    I'm working my way through the Make: Electronics book and one of the first exercises involves fitting a 1.5V AA battery to a battery holder and attaching the leads to a 3A blade fuse.
    Although the book says that the element should break "almost immediately", it doesn't seem to break even after I've held the leads there a number of seconds. Am I doing something wrong?
    One side of the fuse says "iMAXX 3" and the other says "32 V", if that's any help.
  2. #12
    Nov 30, 2010
    16,665
    7,313
    Are you sure the instructions did not say to attach a D battery or a car battery?
    You're trying to tow a car with a mouse. The AA battery has too much internal resistance to deliver more than 3 amps.
    drguildo likes this.
  3. kubeek
    Sep 20, 2005
    4,687
    805
    could be your batteries are just old and weak.
  4. drguildo
    Jan 15, 2014
    14
  5. R!f@@
    Apr 2, 2009
    8,785
    771
    1.5V cells cannot break 3A fuse, Mate.
    Not even 9V batteries can do tht.
    But if u try with 12V motor cycle battery, it will.
    But DOING THIS IS DANGEROUS. BATTERY CAN LEAK OR EXPLODE
    DO NOT TRY IT.
  6. mcgyvr
    Oct 15, 2009
    4,787
    973
    It all depends on the condition/charge of the battery and its chemistry and internal resistance.
    This will determine its short circuit capacity.
    AA's alone CAN have sufficient short circuit capacity that would cause a fuse to open.
    One datasheet for a battery states 181 milliohms of resistance (internal impedance) and a 1.5V nominal out.
    1.5/.181 = 8.2 Amp short circuit capacity.
  7. drguildo
    Jan 15, 2014
    14
    That's crazy. Why would the person who wrote this book think it could? I mean I believe what you're saying I just can't think why they would put this in the book without at least trying it.
  8. drguildo
    Jan 15, 2014
    14
    I just tried with a 9V battery (multimeter said it was delivering around 8-9V) and that didn't do it either.
  9. Alec_t
    Sep 17, 2013
    5,967
    1,134
    Trying to blow the fuse with an AA cell will deplete the cell very quickly if the fuse does not blow immediately. Sounds like a daft experiment to me.
  10. R!f@@
    Apr 2, 2009
    8,785
    771
    Told Ya !
    Try the latest 2000mA ones. I don't think it will either
    But a good li-on might
  11. drguildo
    Jan 15, 2014
    14
  12. BillB3857
    Feb 28, 2009
    2,402
    348
    Try it with a fully charged Ni-Mh or NiCad. Energizer's data sheet for a AA size shows that it can maintain 3250ma for about 15 minutes before the voltage drops to 0.9v.
  13. inwo
    Nov 7, 2013
    2,435
    315
    I'd say it's busted!
    A new AA draws 4 amps thru normal test leads, ammeter, and that type fuse.
    Not enough to blow a slow fuse.
  14. drguildo
    Jan 15, 2014
    14
    So could it be because the only battery I know is brand new is a cheapo brand? It's a Morrison's own-brand one which says AA/LR6/1.5V on the side.
  15. alfacliff
    Dec 13, 2013
    2,449
    428
    how about the wire size? and the battery holder also has some resistance. too small wire can reduce available current.
  16. drguildo
    Jan 15, 2014
    14
    When I use a multimeter to measure the voltage on the ends of the wires it's giving out between 8-9V. I don't really know how this translates to amps.
  17. mcgyvr
    Oct 15, 2009
    4,787
    973
    It doesn't necessarily.. Its just a measurement of the available voltage.
    I think you skipped some chapters in the book.. Back to the basics..
    basics..then experiments..then more advanced..then more experiments..
    "walk before you run" blah blah blah..
  18. Alec_t
    Sep 17, 2013
    5,967
    1,134
    Something inconsistent here:
    If Morrisons are selling 1.5V cells that give out 8-9V, I want a barrow-load :).
  19. drguildo
    Jan 15, 2014
    14
    Sorry. The 8-9V was from measuring the output of the 9V battery.
  20. drguildo
    Jan 15, 2014
    14
    So how would I go about measuring the amps? There's an "A" mode on my multimeter but I can't seem to get a reading using it.
