36v to 12v
Discussion in 'General Electronics Chat' started by demonkid, Mar 26, 2006.
  1. demonkid
    Mar 26, 2006
    ok i want to convert 36volt @ 9 watts to 12 volt's
    where would i get a converter at and 1 more ?
    if i did convert the 36 volt to 12 volt wouldent the amount of watts go up also since i am
    going down in voltage.
    thx in advance.
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    If the power went up you would have created a device with greater than 100% efficiency, aka a perpetual motion machine. In any conversion scheme power in will always be greater than power out. Do you want to buy one or build one?
    If you are buying one , assume you had a converter that was 80% efficient. 36 Volts and 9 Watts is 250 milliamperes. 9 Watts times 0.8 is 7.2 Watts. 7.2 Watts divided by 12 Volts is 600 milliamperes.
    So when you drop the voltage there is more current available but there is always a power loss. Where does that 1.8 Watts go? Up the chimney mate, it's lost and gone forever as heat.
  3. david mendes
    Mar 23, 2006
    6
    If you mean AC, a transformer 3:1 will do...
    If you mean DC, find 7812 chip and a couple of capacitors to put on IN and OUT pin.
    David Mendes
  4. Gadget
    Distinguished Member
    Jan 10, 2006
    613
    Lets assume your talking DC voltage here....
    I also think you may mean "Amps" or current, not the "watts" going up.
    If you use a Switch Mode regulator/converter, then yes, you should end up with more current, and only a slight reduction in the "Wattage" (i.e high efficiency, low power loss).
    If you use a linear regulator such as the 7812 then you will get no increase in current, as 2/3 of your "Wattage" (Power) will be wasted as heat in the regulator. It will get real hot, and need to be mounted on a heatsink so that all that wasted power can be used to warm up the box it's all mounted in... i.e. it will be Inefficient, and with 36v going into it, will be running at (or possibly above) it's maximum ratings.
  5. demonkid
    Mar 26, 2006
    yea i am talking about dc voltage
  6. windoze killa
    Feb 23, 2006
    605
    24
    Powerbox, Amtex and Lambda all produce modules that do exactly what you want. Havwe a look at their web sites.
  7. demonkid
    Mar 26, 2006
    thx and could you give me the links to the web sites? i'll google them but if i cant find them i wanna have something to come back to
  8. windoze killa
    Feb 23, 2006
    605
    24
    www.powerbox.com
    www.amtex.com
    www.lambda.com ??? I think
