Need to build a permanently connected battery charger for a 36V 7Ah lead acid battery pack. On/off control on the 220VAC side. Considering utilizing a LM317 regulator with a Zener/diode combination on the Adj leg to get 43.5 volt output with 1A max. Will this work or am I going to release the smoke contained in the regulator?
