36 volt electric boat 24v gauges
Discussion in 'The Projects Forum' started by 0meridian, Jun 10, 2009.
  1. 0meridian
    Jun 10, 2009
    Hi All,
    I am a newb and just getting started in electronics.
    I am working on an electric boat with a nominal battery pack voltage of 36v. The problem I have is one of the gauges...an Hour meter...runs on 12/24 volts. I am sure this gauge uses less than 1 Amp can I just use a resistor or do I need a whole voltage regulator.
    Thanks!
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Only if you know the resistance of the gauge, and only if the resistance of the gauge is constant. Otherwise, you'll have to spend a whole whopping quarter on that regulator!
  3. Bernard
    Aug 7, 2008
    4,248
    424
    Could put a 12V zener diode in series with meter & 36V, 5W?, good for about 400mA.
