Huh?I was comparing the typical application schematics between the MC34063 and the NCP3063.
The NCP3063 shows pin 8 (driver collector) is NOT connected while 34063 does.
I'm looking on page 11 of 19 of the PDF.
SWC is pin 1. It's connected to the junction of the inductor L101 and the diode D101.
Higher switching frequency. The small caps help a great deal with transient suppression at high frequencies.Also, the application shows 5 total capacitors for the NCP, only 3 for the 34063.
Why do you need a .1uF capacitor in line with polarized electrolytic caps? That's where the 2 extras are coming from.
Oh, I blew it on the input cap; I linked to a 100uF low ESR; it needs to be higher.
It is. Try downloading the PDF again; you might have a corrupted version.Why is the driver collector not connected in the NCP version?
No, absolutely not.One last question, should the 12V input ground be independent from the (in my case) 18V output ground?.
On your board, all of the grounds must be common. Use short, fat traces to minimize inductance.
It wouldn't be a bad idea to run the ground and power to your LED array from the board itself.
