32bit Level shiftter 3.3v to 5v
tks999
Joined Jan 10, 2013
6
Hello guys i have to design 32bit bidirectional level shiftter from 3.3v to 5v
input levels : CMOS.
output levels: CMOS.
Can you help my with some of this questions:
1. Which IC i have to use?
2. How exactly to do 32 bit?
3. What is neccery to connect for check is my scheme working?
Thanks!
WBahn
Joined Mar 31, 2012
30,058
Please post your attempt to work the problem. After all, it is YOUR homework problem. This is the Homework Help forum, not the Homework Done For You forum. So post your best attempt and we will help guide you from there toward a solution, but you will need to do most of the work -- which seems only fair since you will be receiving all the credit.
tks999
Joined Jan 10, 2013
6
The problem is that i don't know the method to do it.
I know i have to choose IC but i don't know which will be correct.
I know that when i choose IC , probbaly will be 8bit and i have to take 4 of this IC. I have to do it , but i don't know how to work with IC.
I don't want anyone to do my work, i just need advices how to start it!
Thanks and sorry if my post looks like i'm lazy or something.
WBahn
Joined Mar 31, 2012
30,058
Well, a failry obvious place to start is doing a Google search for, say, "level shifter". If you explore the first few links that come up, I bet you will either be able to answer your question yourself or at least get a much beffer feel for what the lay of the landscape is so that you can make a decent attempt and be able to ask much more detailed questions.
WBahn
Joined Mar 31, 2012
30,058
One problem you might have is finding stuff that is 5V compliant. A lot of that stuff has been discontinued.
What speed are you trying to run these signals at? If it is slow enough, one option is to do it resistively.
Ron H
Joined Apr 14, 2005
7,063
If you search for "3.3v to 5v level shifter ic", you get several relevant hits.
I guess it's just too obvious.
tks999
Joined Jan 10, 2013
6
Can anybody help me with the block diagram, i think i wii have
Power Supply block, filter,5v fix regulator, 3,3v regulator, and the siffter.
Ron H
Joined Apr 14, 2005
7,063
Draw it and post it, and then we can comment. As usual, you need to take your work as far as you can before asking for help. That's why it's called Homework Help, not *Homework Done For You©.
*Copyright WBahn 2012
tks999
Joined Jan 10, 2013
6
Thank you guys. I completly finish my homework and almost everything was perfect.
Now i know a bit more about
1.How to use IC's
2.Preteus software
3.What is trasnlator and the different types translators.
Thakns, again!
WBahn
Joined Mar 31, 2012
30,058
1.How to use IC's
2.Preteus software
Thakns, again!
Good. That's the whole goal of homework in general and this forum in particular -- and that's why we try to only help around the edges and make the student do the heavy lifting.
