32.768kHz Crystal - Polarity?
Discussion in 'General Electronics Chat' started by demonGeek, Mar 25, 2009.
  1. demonGeek
    Feb 27, 2009
    7
    I'm about to solder up a PCB containing this 32.768kHz Crystal and there's a square pad on one of the legs which is used elsewhere on the board to indicate polarity.
    Is the crystal is polarized and, if so, how do I tell?
    Many thanks.
    - Adam
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    I've never heard of a crystal having polarity, so I'm going to go out on a limb and say they aren't.
  3. demonGeek
    Feb 27, 2009
    7
    Thanks Bill - I didn't think it was polarized but it's the first time I've used one and I didn't want to guess wrong!
    - Adam
  4. wr8y
    Sep 16, 2008
    232
    I'v soldered a lot of crystals in place since 1980 and the only ones that are (sometimes) polarized are those in crystal filter circuits - but even then, they will have three legs! (There will usually be a dot or dimple at one end, this indicates polarity.) But these are not crystals to be used in an oscillator - they are being used as filters.
  5. steveb
    Jul 3, 2008
    2,433
    469
    If you hook a watch crystal up with reverse polarity, time will run backwards. :p
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    .taht wonk t'ndid I ?yllaeR
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Hooked a battery up backwards in a car once.
    Horn sucked, radio listened, headlamps cast shadows.... :rolleyes:
