300W LED Grow Light
Discussion in 'The Projects Forum' started by Dan K, Jul 30, 2010.
  1. Dan K
    Jul 30, 2010
    I decided I want to test out LED technology in the growing environment. I hear very good things. Problem is the pre-built grow lights on the market are very expensive, not worth it. I figure I can cut the cost down a TON if I just make my own. The only requirements are that it is safe and reliable. I am dedicated and willing to learn.
    Right now I plan on using 100 Red & Blue spectrum LEDs that are 3w each. What is the best way to wire all this up? I have no knowledge of LEDs besides the very basics. I have been looking for a place to start picking up info specifically for my project but I have not been finding good results. I am strictly confused on how to wire everything/what components I need. I have no problems constructing a proper housing with a fan or whatever to cool it a bit. I just need some help getting started so I can understand whats going on, anyone have any useful links relevant to this project?
    How hard of a project is this from someone who is a noob? 1-10 rating? If anyone has any how-to information or diagrams that'd be helpful.
  2. windoze killa
    Feb 23, 2006
    605
    24
    Do a search for LED lights here. Someone else has done exactly the same thing.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
  4. mcgyvr
    Oct 15, 2009
    4,798
    979
    <snip>
    Let's see a 150W high pressure sodium fixture/bulb = $100.00 (times 2 for 300W=$200.00)
    Now 100 x 3W LED's at $5.00 each if you get a great deal = $500.
    But assuming you have calculated needing 300W of typical lighting does not equal 100x3W LED's. Typically 15-20W of LED's equals 100W of HID lighting.
    So for 300W of HID you need 60W of LED (20x3Wx$5.00=$100)plus constant current drivers plus heatsinks... I bet you could get away with $250 for a 60W LED grow fixture that would be comparable to a 300W HPS bulb.
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    A lot of folks also try to use grow lights using conventional LEDs. I have no clue how well it works, but I've drawn quite a few diagrams for folks.
  6. bertus
    Administrator
    Apr 5, 2008
    15,809
    2,390
    From the wiki:
    This is the full page:
    http://en.wikipedia.org/wiki/LED_lamp
    Bertus
  7. BMorse
    Sep 26, 2009
    2,675
    234
  8. JDT
    Feb 12, 2009
    658
    85
    And will reduce the thermal signature in the police helicopter I.R. cameras...
    What am I saying - I'm sure you're not going to grow that kind of plant!
  9. BMorse
    Sep 26, 2009
    2,675
    234
    Actually, those are the "plants" they are growing with these types of light, I mean, who's going to go through this much trouble just to grow spices;)..
    Here in MI. There has been a boom in the Medical sale of it and there are a lot of people who are signed up as "providers" that have grow houses all over the place.... I have been approached by a couple of people interested in having me design something for them along these lines......
    B. Morse
  10. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If you please, the OP has a request for a small grow lamp. Commercial growers of illegal plants get caught because their houses glow like a Bessemer converter in IR, and their electric bills are the size of the Pentagon's. 300 watts is just more than a good reading lamp.
  11. Markd77
    Sep 7, 2009
    2,803
    594
    I'd love to grow chilli plants all year and I think it would look good in the corner of the room.
    I'm not sure how important the wavelength of the light is. If I read right it should be 465 and 665 nm. High power blues are available in 465 but most of the reds seem to be 630 nm.
  12. Dan K
    Jul 30, 2010
  13. Wendy
    Mar 24, 2008
    20,772
    2,540
  14. tom66
    May 9, 2009
    2,613
    214
    $100 :eek: you'd be better off building one of your own.
    It really is quite simple. Some resistors and a power supply will be more than enough. For example you could get a 3V 5A supply and try that, wiring all the LEDs in parallel. (You may need a resistor for the reds.) Or you could wire the LEDs in series with say a +24V supply. I could draw up a schematic if you want. But you need to tell us what exactly you want.
