I have a QM300HA-24 transistor module...it has a C (collector) B (Base) E (Emitter) and then its got a BX pin...What the heck is that pin for.????Do i just use the Base.....As for load testing....i attach a 1ohm 300 watt resistor to the emitter and ground it and pull 13 or so amps....but way does approx 20vdc get fed back into the output of my voltage regulator thats putting out approx 13.5 volts???
