3001 in 1 electronics lab schematic help
Discussion in 'General Electronics Chat' started by apac, May 27, 2008.
  1. apac
    May 27, 2008
    On Project 2 Transistor Radio everything seems ok until you get to the connecting wires and instead of just point to point like J14-N14
    it says G11-35-32-31-Ground
    I have tried many ways of connecting this and it still won't work
    can anyone tell me how it should be wired?
    G11 is a breadboard, 35,32,31 are spring connectors and ground I assume is the wire that it tells you earlier to attach to spring 35 and an earth like a cold water pipe
    Can any help me or should I post the schematic?
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    It is always helpful to have the schematic and instructions posted. Otherwise, we may miss some critical information.
  3. apac
    May 27, 2008
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    The 2nd photo is missing the fileId.
    That is, the 2nd photo won't download.
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    Why not use the albums that are part of this site. I am not going to download software to look at drawings, so I can't help much.
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    OK, the 1st photo shows enough.
    G11-35-32-31-Ground
    Connect G11 to 35
    Connect 35 to 32
    Connect 32 to 31
    Connect 31 to a ground.
    Unfortunately, the advice to connect it to a cold water pipe is no longer valid for newer homes in the States, as water pipes have been made from PVC plastic for a number of years now.
    If you want to connect to a real ground, and you're in the States, and your electrical outlets have 3-hole jacks for electrical plugs, then:
    There is a screw in the center of the outlet that holds the plate on. This screw is connected to electrical ground in the dwelling, and eventally to earth ground. You can back the screw out a little bit, wrap the end of your ground wire around the screw, and re-tighten the screw.
    If you aren't in the States or don't have three-hole outlets, then try the water faucet.
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    My Internet connection decided to croak on me in mid-post :rolleyes:
    At least I managed to copy the text out before it went off into the bit bucket.
  8. apac
    May 27, 2008
    I understand what you are saying but........:)
    in an earlier step you connect a wire from 35 to ground, so is there any need to go from 31 to ground directly? could you just go from 31 back to 35 or not have any wire as it does eventually go from 35 which is grounded to 31
    Or is it as simple as these points are not connected back to earth and therefore you must run 2 seperate earths from 31 and 35?
    I know i am a newbie at some of this but it seems a kinda confusing way to word it in a beginners book.
    Anyway thanks for your help, apologies did not realise there was a gallery or if it would have shown up clearly enough in there and I assumed windows or mac would display the picture without any special download.
    Also I am in Australia so I will try the tap
  9. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Um... no!
    The first time pin 35 is referenced is right after G11; you connect a wire from G11 to 35.
    It doesn't mention connecting pin 35 to anything prior to that...
    Unless you didn't remove Project 1 before starting in on Project 2! :eek:
    Double-check all of the parts and wires that you've put in thus far; it should rather look like the drawing under the "Project 2" title.
    Note under R1, at location G11 - there's a wire coming out of that socket, and running to the left, pointing at 35. It gets connected there.
    Then note too, on the left side of the 30's terminals - 31, 32, and 35 are all connected together. Then there is another wire running from 35 off the board to earth ground.
    So there are three connections to terminal 35. This is normal - happens all the time!
  10. apac
    May 27, 2008
    step 9 should not be taken as a seperate step to the actual wire connections but more as a guide, is that correct?
  11. cumesoftware
    Apr 27, 2007
    1,330
    11
    Looks like the kit my brother had. Only infinitely better. My brother's was made from cardboard and only had 33 circuits.
  12. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Yes, that's correct. Now I see what you're talking about. I was getting tired when I scanned the instructions, and I skipped that reference somehow.
    I agree, it could be written more clearly. They should've had the "Connecting Wires" paragraph first, and the 35-to-ground connection flagged with an asterisk (*) with the explanatory paragraph below.
