Hi can you be a little more specific, what are the input/output voltages, and what is the output going to power? lights? charge batteries? etcI am trying to find a plan to build a 30 amp line conditioner /voltage regulator for a rv. Can anyone help with a drawing or advice on were to search
120volt ac input 120 volt output 30 ampHi can you be a little more specific, what are the input/output voltages, and what is the output going to power? lights? charge batteries? etc
once those parameters are known it is easier to make some recommendations.
That certainly would do the job but seems a little overkill, I wonder why if he's using standard fridges etc, he needs anything more than say spike/ noise suppression from the incoming line voltage. Over to you Scotty63something along the lines of ??
http://www.farnell.com/datasheets/1670853.pdf
If that's what is needed, I would think that buying a unit like this is probably the best answer as at least you have a proven design with a guarantee if it blows up! To home build one would be costly and no guarantee!
Thanks for all your time. It's just a thought if it is to complicated I will just buy one. I wanted to at least see what was involved. I will look at all the links you sent when I get out of work thanks againsorry if I sound like an ass this morning. been up a while now and the pain meds are really kickin my butt
