3 Watt LED array with 1 watt resistors; Power Supply questions
Discussion in 'The Projects Forum' started by LEDwire, Mar 25, 2015.
  1. LEDwire
    Mar 1, 2015
    12
    I just finished wiring an LED array with several series of 5 3-watt LEDs (~2.3 volt fV, 13.8 V power supply, 350 mA max current) with a 4 ohm, 1-watt ceramic resistor wired to each series to limit current.
    I just realized these resistors may be limiting the brightness of my LEDs. If the resistors are rated at 1 watt, and the LEDs are 3 watts, will they limit the brightness of my array?
    Also:
    I have a pyramid PS52KX 52 amp power supply that has an input of 115 volts 60 hz and 1000 watts. Its output is 12-15 volts and 40 amp constant/52 amp surge.
    I have 540 3 watt LEDs in my array at the moment. 540 x 3 = 1620 watts. Do I need a power supply with more watts to get the most output from my LEDs?
    The power supply, at the moment, "flickers" and will put out close to 30 amps then drop down to 20 amps or so, and this happens on and off while the array is lit up. Any idea what could be causing this behavior?
    Thank you.
  2. mcgyvr
    Oct 15, 2009
    4,791
    975
    Wow.. where to start.....
    After this burrito... :)
  3. LEDwire
    Mar 1, 2015
    12
    I know, I know.
    Or, "I don't know," "I don't know."
  4. Dodgydave
    Jun 22, 2012
    5,152
    770
    WOW,your leds need 1620W and your psu is 1000W, definitely need a bigger psu, by the way what are you making , a Cannabis Farm!
  5. mcgyvr
    Oct 15, 2009
    4,791
    975
    So... I'll try to keep this fairly simple.. Because you absolutely need to understand the basics before you even attempt to build such a MASSIVE light..
    First.. 3W LEDs is just a generic term to attempt to classify LEDs into wattage groups.. (and a huge amount of rounding up)
    2.3Vf x 350mA = .805 Watts.. not 3W..
    The 3W comes from the fact that some may have a Vf closer to 3V and can be run up to 1000mA max.. and 3 x 1000mA (1 amp) = 3W
    Second.. LEDs need to be FED current.. hence what the resistor is doing..
    However a resistor is really a bad choice for "high" power LEDs as #1 the Vf can/does fluctuate (which will in turn change the amount of current that the LED is being fed).
    A "constant current" supply (commonly referred to as an LED Driver when used with LEDs) is a much better choice as it is more efficient AND will self adjust to ensure exactly 350mA is delivered to the LEDs.
    The 1W is simply how much heat that resistor can typically safely dissipate.
    Assuming 5 LEDs in series with a vf of 2.3 thats 11.5V..
    With your 13.8V supply the resistor is dissipating
    (13.8-11.5) x .350 = .805 watts
    One should ALWAYS double (or triple) the calculated wattage so a resistor doesn't run too hot..
    I would have used a 2W resistor.. (well I would have used an LED driver instead)..
    The circuit will function identically but the resistor will run much cooler to the touch..
    Now you have a 4 ohm resistor.. Lets do some math for that..
    (13.8-11.5)/4 = .575 Amps (or 575mA)..
    So you are feeding those LEDs 575mA... NOT 350mA
    So lets start with that and see how that sinks in...
    Google "Ohms wheel" and see where the math comes from...
  6. mcgyvr
    Oct 15, 2009
    4,791
    975
    Little more math..
    Assuming the same strings/4 ohm resistor..
    If your large supply is outputting 12V..
    Then (12-11.5)/4 = .125 Amps (125mA).. now you are drastically underdriving them..
    If your large supply is outputting 15V...
    Then (15-11.5)/4 = .875 Amps (875mA).. now you are overdriving them..
    With big LEDs.. I'm 100% in the use a LED driver camp..
    I would highly recommend eliminating the resistor and using a Meanwell LDD driver (350mA version)..
    That will ensure your LEDs are always getting 350mA..
    But it does require your supply voltage be approx 2V higher than the Vf..
  7. mcgyvr
    Oct 15, 2009
    4,791
    975
    Flickering..
    With LED drivers "flickering" typically happens when the VF of the string is less than or greater than the rated DC output voltage of the driver.. So it flickers trying to maintain the constant current..
    Anytime I've seen that its typically too many LEDs in a string and removing one solves that problem..
    Not saying thats the problem here.. but more than likely the supply cannot "supply" and is in a "safety..oops mode"..
  8. mcgyvr
    Oct 15, 2009
    4,791
    975
    And Vf is only an "average".. It could be 1.8V or it could be 2.5V (typically the datasheet will show a min/max/average Vf)
    Slight changes/differences in the Vf can really change the math above...
    Hence why a constant current LED driver is better.. It adapts to that change as best it can..
    A resistor is "fixed" and cannot adapt..
  9. mcgyvr
    Oct 15, 2009
    4,791
    975
    At least you got close on the resistor (by some stroke of luck I'd guess).. way too many people think LEDs are just like lightbulbs and you just need to attach a power supply to them..
    That always ends in "smoke"...
  10. LEDwire
    Mar 1, 2015
    12
    Thanks for your messages. That helps clarify things.
    I did check the forward voltage of each LED with a voltmeter and grouped them so they averaged about 2.3 volts across each 5 LED string.
    Is it possible to connect an LED driver and simply unsolder the resistors and keep the array wired as is in 5 LEDs per string? You mentioned an LED driver requires 2 volts higher than forward voltage--is this total per string or per LED?
    Thank you. I really appreciate your help.
  11. mcgyvr
    Oct 15, 2009
    4,791
    975
    The LED driver like the meanwell will "eat" up 3 volts (sorry said 2 its 3) just like an LED "eats" up 2.3
    http://www.meanwell.com/search/ldd-h/LDD-H-spec.pdf
    Best part is you can dim the strings with 5V PWM..
    It would have been much more efficient to use a higher voltage (48V supply) and put more in series...
  12. LEDwire
    Mar 1, 2015
    12
    So if I were to purchase one of these, could I use it with my current arrangement and set my power supply to 14.5 volts (3 v for the driver, 11.5 [2.3 fV * 5] for the LEDs) and the current would be constant at 350 or 300 mA?
    If the LEDs I have are rated for max current of 350mA, but I use them only for 20 minutes at a time (this whole LED array is for a skin therapy application, treatment times last 20 minutes), would this significantly affect their working life? Or would it be better to get a 300 mA driver and run them a bit below max?
    Thanks again.
  13. John P
    Oct 14, 2008
    1,638
    225
    And I really hope you're mounting those LEDs on a good heat sink. Even an "efficient" light source like an LED turns most of the energy it receives into heat.
  14. LEDwire
    Mar 1, 2015
    12
    They're surface mounted onto through-hole board with a fan cooling them whenever they're lit up.
  15. mcgyvr
    Oct 15, 2009
    4,791
    975
    ??? pics or something please..
    You absolutely need these mounted to a heatsink..
  16. LEDwire
    Mar 1, 2015
    12
    Here are pics. Ugly, I know. But functional.
  17. MCU88
    Member
    Mar 12, 2015
    360
    35
    What the bloody hell is it?
  18. mcgyvr
    Oct 15, 2009
    4,791
    975
    WOW..
    Did you do any temperature testing prior to spending ALL that time?
    I really expect a "greatly" reduced lifespan like that unless you only turn them on for a few minutes or so..
    I can't believe you actually did that.. That goes in my WTF folder for future use/laughs..
  19. LEDwire
    Mar 1, 2015
    12
    It's a light therapy array for rosacea (a skin condition that responds favorably to red light exposure).
    I use a box fan to cool it while it's in operation. The LEDs are typically lit for 20 minutes per day like that.
  20. LEDwire
    Mar 1, 2015
    12
    So, mcgyvr, if you were going to produce something with that density of 3W LEDs for this application, what would you do differently?
    Thanks.
