I was studying a voltage regulator circuit.
In that I found a small transformer of 3 terminals. So can anyone tell me about its use and function of terminals.
the terminals were connected to diode 1N4007, transistor,resistor in parallel with capacitor.
The circuit was also used to charge battery(1000mAh) and 1.1V.
The output voltage of circuit is 1.2V.
Thank You.
Thank You.
