3 Switch LOGIC Circuit
Discussion in 'Homework Help' started by johncena, Aug 29, 2010.
  1. johncena
    Aug 15, 2010
    32
    We need to setup a 3 switch wherein if more than 2 switch are open, the LED will light. Materials should only be 2 transistor NPN and 2 PNP transistors, LED , resistors and wires. If switch is off it will generate negative volt, else, it will give +5 volts ( There is also a separate - and +5 volts source aside from the switches) (Switches are from the Digital trainer). It doesn't matter where LED will glow very bright, as long as there is a light on led, it counts as on.
    Is it possible to make a circuits with only 2 NPN and 2 PNP transistors?
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    What have you been able to come up with on your own so far?
    hgmjr
  3. johncena
    Aug 15, 2010
    32
    still unsuccessful. I made 3 AND gates and 1 OR gate (without doing the required limited transistors). But the output is wrong
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    Have you drawn up a truth table? It is then possible to make a network to match.
    Can you use diodes, or are transistors it?
  5. johncena
    Aug 15, 2010
    32
    Here:
    0 0 0 = 0
    1 0 0 = 0
    0 1 0 = 0
    0 0 1 = 0
    1 1 0 = 1
    1 0 1 = 1
    0 1 1 = 1
    1 1 1 = 1
    No diodes, just Transistors as a Basic ON and OFF switch (General Purpose Transistors)
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    Just a suggestion, whenever you make a logic diagram use a sequential count. Patterns show up better too.
    0 0 0. 0
    0 0 1. 0
    0 1 0. 0
    0 1 1. 1
    1 0 0. 0
    1 0 1. 1
    1 1 0. 1
    1 1 1. 1
    Ever study how to build a Schmitt trigger using transistors? You may be able to set up a voltage comparator threshold using resistors and transistors.
  7. Georacer
    Nov 25, 2009
    5,151
    1,266
    I really can't see how this can be materialized. Give me 6 npn's and 4 pnp's and sure, I 'll do it, but with such a tight budget I'm at a loss.
