3 Stage FET-BJT Amplifier Analysis
Discussion in 'Homework Help' started by eceturtle, Nov 24, 2015.
  1. eceturtle
    Jul 18, 2015
    We're supposed to analyze this circuit and this particular question asks us to find the drain current of the mosfet. I keep getting an answer of Id = 3.54mA and Vds = 6.3675V. Since the gate voltage is zero Vgs = 0-Vs= -Vs. Using the current flowing through the source resistance, I came up with Vs = IsRs - 7.5V. Since the source current is equal to the drain current, Id = 0.5*kn*(Vgs-Vtn)^2 = 0.5*kn*(-Vs-Vtn)^2. I plugged in the eqn for the source current in the expression for Vs which leaves Vs as the only unknown and then obtain Vs = -1.8411V, then I plug in Vs into the eqn for the drain current and solve for Vd, for which I get Vd = 4.5264V. Thus Vds = 6.3675V.
    Can someone point out where I'm making an error?
  2. WBahn
    Mar 31, 2012
    18,087
    4,917
    Are you taking into account lambda? Though it is small enough I would not expect it to have a huge effect.
    Also, of the answers offered, how many are physically possible?
  3. Jony130
    Feb 17, 2009
    3,991
    1,116
    But can you explain me one thing. How can this N-MOS be ON when his gate is at 0V and Vt has positive value Vt = 1V?
  4. WBahn
    Mar 31, 2012
    18,087
    4,917
    The gate is at 0V, but the source is pulled down toward -7.5 V through a 1600 Ω resistor.
  5. Jony130
    Feb 17, 2009
    3,991
    1,116
    Are you trying to say is that M1 is a depletion MOSFET ?
  6. WBahn
    Mar 31, 2012
    18,087
    4,917
    Nope.
    The gate voltage itself is irrelevant except in relation so the source voltage. It is the gate-source voltage that matters. If the gate is at 0 V and the source is at -2 V, then Vgs = 2 V and you have plenty of overdrive available.
  7. Jony130
    Feb 17, 2009
    3,991
    1,116
    OK I see it now. I simply didn't notice that the source is not at ground as usual.
