3 signals thru 1 probe to a C.R.O
Discussion in 'General Electronics Chat' started by itsmyturn, Feb 15, 2005.
  1. itsmyturn
    Feb 15, 2005
    16
    HELLO ANYBODY !!!!!!!!!!!!!!!!!!!!
    I HAVE TO SHOW 3 SINUSOIDAL SIGNALS ( CLAMPED TO DIFFERENT D.C LEVELS) SIMULTANEOUSLY ON A C.R.O USING A SINGLE PROBE. HOW CAN I MAKE IT POSSIBLE.
    SECONDLY HOW CAN I GENERATE AN EXACT PHASE DIFFERENCE OF 90 DEGREES.
  2. 1000MFD
    Dec 5, 2004
    If cross-coupling back from the load is not an issue, you can make an analog "AND" using resistors (90Kohms/10Kohms for illustration, you may choose lower resistance, just make all three the same if they are 'nominally' in the same voltage range)... The 90Kohms/10Kohms makes a 10:1 voltage divider.
    AC1 --- 90Kohms -----
    AC2 --- 90Kohms ------------------------ C.R.O. high impedance input
    AC3 --- 90Kohms -----`````10Kohms
    Common (gnd) ----------------------------- C.R.O. signal ground
    For your second question, tis an exercise.... keep in mind the phase will be frequency-dependent ifyou choose to use a passive circuit. Good luck with your homework.
