3 second delay timer on +12VDC circuit.
Discussion in 'The Projects Forum' started by heebz, Nov 8, 2009.
  1. heebz
    Nov 8, 2009
    Hello, I am fairly new to building circuits (last time I've done anything like this is almost 7 years ago). But what I am trying to do is a light turns on when I press a button (the button stays pressed). My problem is the light needs to shut off after 3 to 5 seconds OR when the button is let off.
    It just needs to be something simple, Input power is applied, output turns on for 3 to 5 seconds or till input power is no longer applied.
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
  3. heebz
    Nov 8, 2009
    Ok, so this is suppose to be in my car, so how would i go about making this into a chip or something and putting it in my car?
  4. ibegbu_e
    Nov 8, 2009
    16
    Have you tried using electromechanical timer. Connect the core to your 12vdc supply and use the nomally open contact of the timer to control the light. Set it to 3seconds and it will do all you want
