3-Resistor Linear Voltage Divider?
Discussion in 'Homework Help' started by TechRat, Apr 13, 2011.
  1. TechRat
    Oct 20, 2010
    Hello All
    I need to shift the output voltage of my DAC for my temp control.
    I won't bore you with the details, but basically I have a constant 4.096V available, my Vin from the DAC is 0V -> 2.048V and the temp range I'm interested in is 2.132V -> 3.156V. So...
    Vin = 0V, Vtemp = 2.132V
    Vin = 2.048V, Vtemp = 3.156V
    Real estate is very valuable, and I feel like I can accomplish this with a 3-resistor network (see pic) instead of an opamp - but my simultaneous equations math is apparently a little rusty.
    Can anyone help me out with A. Feasibility and B. Solving methods?
    Thanks!
    http://yfrog.com/h4h4nfp
    ---> Pic
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Unfortunately that won't work.
    The 'proof' would go something like this ...
    Reduce V1, R1 & R3 to a Thevenin equivalent Vth & Rth.
    Case 1: If V1=0 then Vth=0 and require Vtemp=2.132V
    Vtemp=2.132=V2*Rth/(Rth+R2)=4.096Rth/(Rth+R2)
    Or
    Rth/(Rth+R2)=2.132/4.096=0.5205
    Case 2: If V1=2.048 Then Vtemp=3.156V
    But
    Vtemp=(V2-Vth)*Rth/(Rth+R2)+Vth
    3.156=(4.096-Vth)*Rth/(Rth+R2)+Vth
    3.156=4.096*Rth/(Rth+R2)+Vth(1-Rth/(Rth+R2))
    3.156=2.132+Vth(1-0.5205)
    1.024=Vth*0.4795
    or
    Vth=2.136V
    But you have set V1=2.048V for this case, which means that a Vth of 2.136V cannot be realized. V1 would have to be greater than 2.136V for this to occur.
    TechRat likes this.
  3. TechRat
    Oct 20, 2010
    Thanks t_n_k!
    I was afraid I just couldn't do math. I appreciate the help!
