3 position Switch logic
Discussion in 'The Projects Forum' started by hupa, Nov 28, 2012.
  1. hupa
    May 19, 2011
    8
    Help please, I am a digital dunce, and not at ease with logic circuits.
    I have 3 membrane buton switches each with an associated LED.
    Here is what I want....
    a) The button pressed dominates (cancels whichever of the other 'positions' was on), and latches.
    b) No strange latchups if more than one button pressed accidently.
    c) On power up a jumper determines which 'position' is on.
    d) Could your idea be extended to N positions with N buttons?
    I have supplies of +5, +12, +- 10 & +- 15 available. Load is minimal.
    Any ideas please? It seems so straightfoward, but I'm struggling, and I refuse to use a micro.
  2. ErnieM
    Apr 24, 2011
    7,436
    1,625
    Each LED is controlled by a set/reset flip flop. Each button will drive the SET input of it's flip flop, and thru an OR gate RESET all flip flops NOT driven by it.
    Using a diode OR scheme would allow this to be extendable to N stages.
    The power on set scheme would be similar, OR to the SET of the on device, and to the RESET of all other devices.
  3. hupa
    May 19, 2011
    8
    Thanks Ernie
    I'm off to the bench shortly, will report progress.
    Care to post a circuit?
