3 Position Solenoids
Discussion in 'General Electronics Chat' started by Skeebopstop, Nov 6, 2012.
  1. Skeebopstop
    Thread Starter Active Member
    Jan 9, 2009
    358
    Dear All,
    I am working on an application at the moment which is going down the path of a DC motor with position feedback whereas a 3 position solenoid could do the job (if they exist?). Anybody know of any solenoid manufacturers that do such 3 position solenoids in rotary and linear form?
    Cheers,
    Skeeb
  2. crutschow
    Mar 14, 2008
    13,501
    3,376
    What are you trying to do with this solenoid? Knowing that will help with suggestions.
  3. Skeebopstop
    Jan 9, 2009
    358
    Well we have an application which drops an arm in by a spring action but needs to be pulled back off with a cam type solution which has two backed off positions. One is not very far from the loaded position whereas the other requires a fair movement which is currently done by 180 degree rotation of the cam.
  4. shortbus
    Sep 30, 2009
    4,096
    1,692
