3 pins of mobile battery
Discussion in 'General Electronics Chat' started by aamirali, Jul 21, 2014.
  1. aamirali
    Feb 2, 2012
    415
    Two pins of mobile battery is +ve & -ve.
    Third I serached is for NTC.
    What how come NTC be put inside battery. Usually battery is dc source, any other electronics is placed outside battery. It caanot be placed inside battery.
  2. MrChips
    Oct 2, 2009
    12,622
    3,451
    NTC resistor is used to measure the temperature of the battery.
  3. Dodgydave
    Jun 22, 2012
    5,130
    766
    Its for a Thermistor in side to prevent over charging, see charger circuit.
  4. shakilabanu
    Member
    Jul 8, 2014
    44
    As Dodgydave has shared most mobile phone batteries not just have a thermistor inside them, but a small PCB too carrying an entire protection and over charge prevention circuit inside them...
    If it had only two terminals then in most cases that is just a Li Ion cell, which is similar to any other cell that you are comparing the battery with.
