3 Phase Series Equivalents (Wye & Delta)
Discussion in 'Homework Help' started by jegues, Oct 12, 2011.
  1. jegues
    Sep 13, 2010
    735
    43
    See first figure attached for my solution to the series portion of the problem.
    The answer they give to the problem is,
    Z_{series} = (1.84 - j1.38) \Omega
    I would agree if this was a Y connection but it asked for the equivalent for a delta connection.
    I first calculated the equivalent for a Y connection and converted it to a delta afterwards.
    I based my reasoning on one of the other examples given in my text. (See second figure attached)
    Is the solution they give incorrect or am I misunderstanding something?
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    My approach would be to find the parallel delta configuration first. I assumed the 208V is the line-to-line rms voltage.
    Given the power per phase is 5kW then the delta (per phase) parallel resistance will be
    Rp=208^2/5000=8.6528Ω
    Zp=Rp||-jXc [capacitive since it's a leading power factor]
    Z_p=\frac{1}{\frac{1}{R_p}+\frac{1}{-jX_c}}=\frac{R_pX_c}{X_c+jR_p}
    arccos (pf)=36.87^o=arctan(\frac{R_p}{X_c})
    or
    R_p=tan(36.87^o)X_c
    or
    X_c=\frac{R_p}{tan(36.87^o)}=\frac{8.6528}{0.75}=11.537 \Omega
    So Zp = 8.6528Ω||-j11.537Ω = 5.538-j4.153 Ω
    The per phase delta series equivalent of the parallel combination would therefore simply be
    Rs=5.538Ω and Xs=4.153 Ω (capacitive reactance)
    So our answers agree, although you didn't derive the parallel equivalent for part (b)
