3 Phase Rectifier
Discussion in 'General Electronics Chat' started by enigmapaul, Dec 12, 2008.
  1. enigmapaul
    Dec 12, 2008
    If I need a solid 350VDC output from a 3-phase generator, can someone point me to the equations to use to figure out how much peak to peak voltage I must maintain on the output of the generator to achieve the DC voltage out using a 3-phase rectifier?
    Thanks!
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    When you rectify an 3 phase signal, the top voltage is the same as in a single phase.
    The avarage voltage will be higher as in a single phase, beacouse the ripple is much smaller.
    See also teh AAC eBook :
    http://www.allaboutcircuits.com/vol_3/chpt_3/4.html
    Greetings,
    Bertus
  3. enigmapaul
    Dec 12, 2008
    Thanks what is the equation to determine the average DC voltage output of the 3 phase rectifier?
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
  5. mik3
    Feb 4, 2008
    4,846
    63
    Vdc=1.35*VL
    Vdc=output voltage of the rectifier
    VL=RMS value of the line voltage
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    That's an extremely rough approximation even at low voltages, and the accuracy is much worse at higher voltages.
    A closer approximation would be:
    Vdc=1.4142*(VL-VF)
    where:
    Vdc= output of the rectifier
    VL = RMS of the line voltage
    VF = Forward voltage of the rectifier(s) in series
    But this still does not account for smoothing capacitors and current in the circuit.
