3-phase problem
dan_man555
Joined Sep 1, 2010
18
A real short one:
If a 3 phase load is calculated at 85kW, with a power factor of 0.87, calculate the apparent power (kVA) and the line current per phase (A/ph).
Help would be much appreciated.
dan_man555
Joined Sep 1, 2010
18
I was thinking:
arccos(0.87)=29.54°
cos(29.54)=85/(apparent power)
apparent power = 97.7kVA
Not sure how to get line current per phase
t_n_k
Joined Mar 6, 2009
5,455
Why not then simply write ...
Apparent Power = (Real Power) / (Power Factor)
You can't find the line current(s) unless you know the line or phase voltages.
