3 phase motor
Discussion in 'General Electronics Chat' started by rcraggs, Jan 30, 2010.
  1. rcraggs
    Jan 30, 2010
    Im looking for a calculation for Full Line Current but I only have a voltage rating of the motor and the Horsepower any suggestion ??
  2. sgardner025
    Nov 5, 2009
    79
    What HP and voltage? If you know the efficiency and power factor ratings you could use (HPx746)\(Voltagex1.73xEfficiencyxPF). Table 430.250 from the NEC will also give you a rating.
  3. obadosa
    Aug 2, 2007
    it is usually assumed that the power factor and efficiency of a three phase motor are 0.8 and 0.85 respectively.
    I hope it helps
  4. BillB3857
    Feb 28, 2009
    2,402
    348
    A rule of thumb we used is 1-1/2 amps per horsepower at 480VAC 3 Phase. Not exact, but pretty close.
