3 phase midpoint connected rectifier
Discussion in 'General Electronics Chat' started by shespuzzling, Oct 11, 2012.
  1. shespuzzling
    Thread Starter Active Member
    Aug 13, 2009
    88
    Why can't 2 diodes conduct at once in a 3 phase 3 pulse rectifier? When 2 of the phase voltages are positive, I don't see why only one diode conducts.
    Thanks!
  2. mlog
    Member
    Feb 11, 2012
    276
    36
    It would help if you would post a schematic.
  3. JDT
    Feb 12, 2009
    658
    85
    The diode on the most positive phase will conduct only. For a very brief instant, when two phase have the same voltage, two diodes will be conducting.
    I assume you are talking about a 3-phase (half wave) rectifier.
  4. shespuzzling
    Aug 13, 2009
    88
    Yes a half wave rectifier, here's a schematic http://www.eece.ksu.edu/~starret/589/man/Efig3.gif
    Does only one diode conduct because the other 2 are actually reverse biased? How can you figure that out? Is there a way to prove it by circuit analysis?
    Thanks!
  5. gerty
    Aug 30, 2007
    1,154
    304
    Don't forget the phases are 120° out of phase from each other.
  6. Dodgydave
    Jun 22, 2012
    5,143
    768
    Only one diode will conduct per phase cycle, the diode with the most voltage takes first phase, then as its phase decays, and the other phase increases, the second diode takes over, then onto the third phase , then back to the first, the same on the negative cycles.
    in a full bridge, only two are ever in full conduction( pos and neg cyles) otherwise you would be shorting out the phases.
  7. crutschow
    Mar 14, 2008
    13,477
    3,362
    If you view the voltage waveform for the three phases on one graph (such as here) you will see at which point each phase has a higher voltage and polarity as compared to the other phase the diode is connected to. That will tell you which diode is conducting.
