3 phase inverter - working!
Discussion in 'General Electronics Chat' started by ShaunManners, Oct 10, 2008.
  1. ShaunManners
    Thread Starter Active Member
    Feb 16, 2008
    72
    Hi SgtWookie,
    Just thought you'd like to know that the 3 phase inverter finally turned the alterantor! :D
    I used some more heavy duty gate drivers capable of delivering 2A to the gate.. left in the 100Ω gate resistor and it worked perfectly.. When I applied 12v to the rotor of the alternator, it stopped dead though... but that turns out to be a too high frequency (450hz)... I experimented and found that 25hz works... I'm not sure if thats the optimal frequency but hey :) maybe its got something to do with voltage/frequency... but I'll have to go and research that a bit.
    Thankyou so much for all of your help... the car headlamp setup was an inspiration... it was invaluable!
    Cheers
    Shaun
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Great news! :)
    Well, if the gate drivers are capable of delivering 2A, then you really should reduce the series gate resistors to take advantage of their improved current carrying capability.
    You're not changing the direction of current through the rotor, are you? It should just go one way, with a "flywheel" diode to let the current continue flowing when the MOSFET cuts off.
    It's been a good while and many other projects between, and I'm afraid I don't remember the particulars. It would help if you'd post updated schematics and explanations of what signals you had going where. ;)
