3 phase induction motor windings
Discussion in 'General Electronics Chat' started by jut, May 4, 2010.
  1. jut
    Thread Starter Senior Member
    Aug 25, 2007
    224
    Are these the correcting windings for a 3-phase induction motor? Are the windings wrapped in the correct direction? I think they are, but I'm not sure.
  2. Jazz Bass Special
    Apr 9, 2010
    24
    5
    I am not an expert, but I believe the "B" winding must be wound the opposite of A & C.
  3. rjenkins
    Nov 6, 2005
    1,015
    69
    I'd think it was OK as drawn, but I'm not an AC motor expert.
  4. Jazz Bass Special
    Apr 9, 2010
    24
    5
    Yeah, I did a little added research at lunchtime.
    It looks fine.
  5. jut
    Aug 25, 2007
    224
    Did you happen to find any websites that showed the direction of windings?
  6. FastEddie
    Jul 14, 2007
    35
  7. Jaguarjoe
    Apr 7, 2010
    770
    90
    I don't think the direction of the windings is important because you don't know the relationships of the three phase power feeding the motor. That's a common problem with a three phase motor-you won't know which way it spins until you hook it up. If its backwards switch any two leads.
  8. jut
    Aug 25, 2007
    224
    I built and tested the above motor. The direction of the windings are indeed correct.
