Hello, today I connected a six wire 3 phase induction motor to an invertor at work (delta conn-invertor output 3 phase 240v) and it ran o.k. The issue is the cable markings U1,U2 etc had fell off. I identified each pair of windings and made the delta connection not thinking about the winding polarity. I obviously got away with it but I have since read if you don't match all the windings polarities you can burn the motor out or it can be noisey. Is this the case and I would appreciate a reason why, never really thought about it before because all the motors I have installed have been labelled. If it is critical how do I determine the correct polarity? Thanks
