3 phase induction motor amperage
Discussion in 'General Electronics Chat' started by madmax0r, Oct 1, 2013.
  1. madmax0r
    Oct 1, 2013
    Quick question,
    Is the full load amperage on a 3 phase motor nameplate the "combined three phase amps" or the single phase, per phase current to determine wire size per phase?
    Thanks in advance, Im new to this forum and wasn't sure where this topic would go so I put it in physics. Hopefully thats the right spot.
    -BH
  2. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    Per phase.
    Max.
  3. madmax0r
    Oct 1, 2013
    thank you sir
  4. madmax0r
    Oct 1, 2013
    I find it very odd that that is rarely specified.. Is it normally only stated if it is 3 phase amps? Any derivative of the horsepower or kilowattage would be a 3 phase amperage... it seems like it should be specified either way..
  5. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    The plate usually specifies FLA (Full Load Amps), this is the value you would expect if you were to measure any phase at full load current.
    The current in the three conductors occurs over 1 electrical rotation of 360°, 120° apart.
    Max.
  6. madmax0r
    Oct 1, 2013
    thanks again max, I suppose it all becomes obvious once you understand the mechanics behind the math well enough. some of the more complex things like calculating power factor lag still gets me a bit twisted up sometimes. The not knowing weather or not it is combined amperage or phase amperage has been a major point of confusion when I'm calculating something 3 phase.
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    It isn't, so I am moving it.
  8. t_n_k
    Mar 6, 2009
    5,448
    783
    There's no inconsistency in assigning the per phase current rating. The convention applies across all components in 3-phase system. Adding the currents over all three phases would be of little use anyway since as you indicate the per phase current rating directly impacts the selection of interconnecting cable conductor size.
