3 phase combination brain pain
Discussion in 'Homework Help' started by Svenny, Jan 10, 2007.
  1. Svenny
    Jan 6, 2007
    The problem states; 6 44ohm resitstors are connected so that 3 form a delta connection and 3 form a wye connection.The 2 banks are then connected in parallel to a 440V supply.
    Calculate current in the wye connected resistors, the delta connected resistors and the total line current.
    I must have missed somthing in class today and have found no examples, HELP!!!
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    What is posing you the issue? Would you like to hazard a guess at the answer?
    If there is something you have missed in your lectures, I would suggest you speak to your lecturer to help you get up to speed. If there is something in your notes/understanding, then please explain where you are having issues, then we can help.
    Dave
  3. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    The two banks are connected in parallel, yes? Voltage is the same for each, yes?
