The equation is 120*f/p, where f is the frequency and p is the number of poles per phase. So Recca02's answer is correct if you assume 10 poles per phase and my answer is correct if you consider a total of 10 (so 10/3) poles. Having said that, in general they give number of poles per phase and you might want to check on that.
Where did the OP state he had a three phase generator?
I don't think I've seen that question ever posed with the total poles as the sum of each pole in each phase, although I'm sure it could happen. It would depend if the instructor's intent is ensuring you read the question.
I think it is 120f/p instead of 60f/p as poles work in pairs to create North and South. Thus in equation they are 60*f/(p/2)= 120*f/p.
I found this to prove that if poles per phase is 10 and frequency is 50 speed is 600.
It's very nice article
maybe in the future we will be able to change the numbers of poles in the machine and consequently to change the valocity but I think that now it's just a nice theory.
