Hello
I have designed a PWM based 3-phase sine generator .
PWM freq = 16KHZ using a Microcontroller and a Look up table for sine
The bridge stage is 3 nos Dual IGBT modules with 10000uf/600v electrolytic capacitor across the input to the bridge and 3 nos 0.22uf/600v capacitors across each module.
I have attached the waveform across R-Y phases and i see a lot of oscillations on the scope.
On looking closely i see this to be the effect of BEMF from the AC motor.
1)The waveform is seen on a CRO since surprisingly the oscillation doesn't show up on a DSO.The frequency which you see is a 30Hz envelope by a 8KHz PWM sine
2)The rating of the motor is 1HP and the leads are quite long (close to 15 meters).
I request someone to comment on this.Maybe pointers or desirably a solution.
Please help
Please help
