With no neutral, then you detect the zero crossing of the voltage measured across each phase.How to detect zero crossing in 3 phase without neutral
Um what? Say that again?I would use the Earth as a reference point and detect between each phase and earth, if you do it between phases you need three circuits.
If there's no neutral, then the earth reference is likely to be rather noisy as compared to the phase voltages.I would use the Earth as a reference point and detect between each phase and earth, if you do it between phases you need three circuits.
