3-input to 8-output switching
Discussion in 'The Projects Forum' started by mikailgarcia, Aug 17, 2013.
  1. mikailgarcia
    Aug 11, 2013
    hi,
    am building a switching circuit that takes an input from 3 pins (3-bit), run through logic gates and provides a high pin on one of the 8 pins output. this is like a binary to decimal, except that only one of the 8 pins should be high.
    am quite not sure if there is already a post earlier, however, i would need some help from anyone who can point me to the right direction, perhaps some sample circuits.
    thanks a lot!
  2. simo_x
    Member
    Dec 23, 2010
    200
    6
    Are you sure there is not a BCD decimal converter for your needs?
    If not, what about using NMOS (maybe logic level) on each output or just using NOT gate?
    Regards
  3. crutschow
    Mar 14, 2008
    13,477
    3,362
    You can use a BCD to decimal (or 3-bit binary to 8) converter such as the CD4028.
  4. rogs
    Aug 28, 2009
    279
    37
  5. ScottWang
    Aug 23, 2012
    4,925
    777
    If you want a switching using 3 pins to choosing one from eight inputs then it should be CD4051, if you want a decoder then you can using CD4028.
  6. rogs
    Aug 28, 2009
    279
    37
    Not quite sure why posters are recommending a CD4028, which is a BCD to Decimal decoder?
    The OP says in his first post that he only requires 8 outputs, not 10 ?
    A 3 to 8 decoder would seem to fit those specific requirements better....or have I missed something?..
  7. GopherT
    Nov 23, 2012
    6,303
    4,021
    absf likes this.
  8. ScottWang
    Aug 23, 2012
    4,925
    777
    If you go to buy something, the thing cost US$10, and then does it matter what you have are US$10 or $20, but you can't only have $9, is that right?
  9. crutschow
    Mar 14, 2008
    13,477
    3,362
    You can use 3-bits of the 4-bit BCD input to get a 3-bit to 8 output decoder. You just ignore the other input bit and the two extra outputs. So whether a 3 to 8 decoder is better depends upon your definition of "better". ;)
  10. simo_x
    Member
    Dec 23, 2010
    200
    6
    The OP has missed to explain the boolean function (or truth table) he needs. :rolleyes:
